HYDROKAPILLA NBU 20 HFE US Lubrication
Klüber Lubrication introduces HYDROKAPILLA NBU 20 HFE US for the lubrication of plain and rolling bearings, and chains. HYDROKAPILLA NBU 20 HFE US is designed for applications that experience high humidity and/or aggressive media.
The grease can be used in drive and carrying chains for wet amusement park rides, carrying chains for textile steamers and any chains subject to aggressive environments (hot water, chlorinated water, steam, alkaline and acidic solutions).
HYDROKAPILLA NBU 20 HFE US, with its enhanced penetration into pin and bushings, reportedly resists corrosion and prevents chain seizure. It can be applied manually, via brush or an automatic spraying system.
