ICECUT 100 and ICECUT 200 Magnetic Drilling Units
Walter Surface Technologies has fully redesigned its ICECUT line of powerful magnetic drilling units and annular cutters. At 22 lbs. and 27 lbs. respectively, the ICECUT 100 and ICECUT 200 mag drills are lightweight.
Looking for powerful, efficient drilling made safe and easy? ICECUT's ACCUDRILL technology protects against overload, overheating and reduces cutter breakage risk.
ICECUT's ergonomic control panel eases operations with centralized controls that enable efficient drilling on either side of the unit.
ICECUT's mandrel support absorbs vibrations for stability and perfect centering, ensuring the motor and chuck are perfectly aligned. Operators get precise cutting with little chance of cutter damage.
ICECUT's lightweight, ergonomic and smooth-grip handle makes unit positioning and drilling operations easy. The unit also features a separate, quick-release and reversible handle for easy positioning in confined spaces.
"Walter's newly redesigned ICECUT units are mobile, lightweight and powerful enough for any job site," explains Ryan Boyd, product manager, tooling and power tools. "There's a tremendous range of features that guarantee the most productive drilling system, and with our ACCUDRILL pressure guide, there is almost no risk of motor overloading, overheating, or premature cutter breakage."
ICECUT's integrated wiring eliminates obstructions when drilling or repositioning the unit. No wires mean no mishandling failures. "That's convenience," says Boyd.
The drilling unit's steel sliding guard keeps operators safe, too. Engage this safety feature for worry-free drilling, free of errant chips and lubricant splash.
Operators will also appreciate ICECUT's easy maintenance. Direct access to the unit's carbon brushes make tune-ups simple and keep ICECUT's motor operating at maximum power.
When mobility is key, check out the ICECUT 100. Its one-speed, 850-watt motor delivers 600 RPMs at 8.5 amps.
When versatility and power is a must, look to the ICECUT 200. Its two-speed 1200-watt motor delivers 300-600 rpm at 12 amps and is ideal for a wide range of job site operations.
What's power without drilling speed? Walter's latest core cutters are guaranteed to drill more holes faster. The company's redesigned annular cutters are toughened with a sophisticated mixture of HSS and aluminum for longer life.
More resistant to instant impact and stress when drilling under load, these annular cutters are less brittle and impervious to deformation.
"ICECUT is a simply a versatile, powerful and safe line of magnetic drilling units and annular cutters," says Boyd. "It's the ultimate core cutting system that helps our customers work better."
