Index-O-Cut high-performance milling system
March 01, 2015
Greenleaf Corp. says its Index-O-Cut high-performance milling system is suitable for machining all materials because of its high-shear cutting action and a 45° lead angle on the octagon-style insert. The facemills can run at high speeds and feeds at low horsepowers. The cutter bodies are made of high-alloy steel and available in imperial and metric sizes from 2" to 5" (50mm to 125mm).
  • gang cutting ( milling)
  • lead angle
    lead angle
    Angle between the side-cutting edge and the projected side of the tool shank or holder, which leads the cutting tool into the workpiece.
  • milling
Sponsored Content
