Wiha Tools has introduced a new line of Industrial SoftGrip Pliers and Cutters. Industrial pliers with cutters feature "Dynamicjoint," a new dimension in strength and durability. Pliers and cutters provide maximum comfort in daily use, smooth operation and optimum force transmission without uncomfortable pressure points. Anti-slip pliers and cutters with soft dual material for safe gripping.
Twenty three styles include: Combination Pliers, Lineman's Crimpers, Stripping Pliers, Long Nose, Bent Nose, Long Flat Nose and Round Nose Pliers, Diagonal Cutters, Cable Cutters and Adjustable Pliers.
Industrial SoftGrip Pliers & Cutters Features:
Requires up to 40 percent less force for cutting, provides extended tool life with less deflection at the cut.
Standard natural brushed finish, special chrome vanadium tool steel.
Precise aligned cutting edges are additionally induction hardened to about 62 HRC.
Soft rounded slip guard molded into grip.
Ergonomic two component handle with non-slip soft grip surface, protects the hand and reduces manual effort and user fatigue.
- fatigue
fatigue
- flat ( screw flat)
flat ( screw flat)
