Insert features serrated cutting-edge geometry for efficient rough milling
Iscar's HELI-ALU LINE of tooling includes a new insert with serrated edges. The new insert, designated as HSM90S APCR 140520R-FWP28, features a radius of 2.0mm (.0787"). It has a super positive and sharp serrated cutting edge geometry, along with a polished rake surface, which ensures efficient milling for aluminum alloys and other non-ferrous materials. (ISO N grade of application)
October 27, 2025
The cutting-edge geometry of the insert splits the chips into small pieces and generates low cutting forces, enabling increased feed rates for higher machining productivity.
Serrated cutting edge advantages
  • Wide chips are divided into small segments. This greatly contributes to effective chip evacuation and diminish negative re-cutting.
  • Reducing cutting forces and decreasing heat generation lessen the mechanical and thermal loads on a tool, enabling prolonged tool life which can be translated into higher productivity by increasing cutting parameters.
  • Improving the tool's dynamic behavior ensures stable cutting in unfavorable conditions (high tool overhang, thin-wall workpieces, poor workholding etc.).
Insert features
  • Wide sharp-edged wiper for improved surface finish.
  • Ground insert periphery for improved precision.
  • Polished rake and relief surfaces to improve chip flow and eliminate built-up edge (BUE).
  • Dividing a wide chip into smaller segments significantly improves chip evacuation, enhancing tool performance even when using high-speed machining (HSM) methods.
  • built-up edge (BUE)
    1. Permanently damaging a metal by heating to cause either incipient melting or intergranular oxidation. 2. In grinding, getting the workpiece hot enough to cause discoloration or…
  • aluminum alloys
    Aluminum containing specified quantities of alloying elements added to obtain the necessary mechanical and physical properties. Aluminum alloys are divided into two categories: wro…
