Inserts for smaller machines and lower depths of cut
Seco's newest indexable milling technology, the Double Turbo 11 milling insert, is designed for smaller machines and shallow cuts. The Double Turbo 11 is a square shoulder solution for face, side, and slot milling, the company says. Its design features double-sided inserts with four cutting edges, delivering cost-effective performance and extended tool life.
Seco’s newest indexable milling technology, the Double Turbo 11 milling insert, is designed for smaller machines and shallow cuts. The Double Turbo 11 is a square shoulder solution for face, side, and slot milling, the company says. Its design features double-sided inserts with four cutting edges, delivering cost-effective performance and extended tool life. Whether working with steel, cast iron, or superalloys, manufacturers can now expand their capabilities and maintain reliability even at lower depths of cut.
According to Seco, the Double Turbo 11 is designed for side milling and slot milling on lower-horsepower machines. The company says its support face reduces load on the center screw by about 25%. A center-locking screw and numbered cutting edges assist insert changes.
