![JET Three-Wheel Belt Bench Grinders for Grinding, Deburring and Finishing JET Three-Wheel Belt Bench Grinders](/sites/default/files/styles/product_image/public/product_images/JET%201x42%203%20Wheel%20Belt%20Bench%20Grinder.jpg?itok=PaDA_Pvx)
The new JET three-wheel belt bench grinders are ideal additions to fabrication and machine shops for grinding castings or deburring and finishing ferrous and nonferrous metal workpieces. To accommodate a wide range of grinding needs on either flat or angular surfaces, these grinders come in three sizes, including 1” x 42”, 2” x 48” and 2”x 60” belt diameters.
The belt grinders are built for the long haul with heavy-duty, casted bodies and die casted belt levers. A vented full motor shroud keeps dust and chips away from the motor shaft. The motor also is protected by a thermal reset to prevent overheating.
Three-wheel design provides fine grinding surfaces. Abrasive belts are equipped with urethane drive and idle wheels for dependable and long-lasting service. An intuitive, lever-based belt tensioning process makes belt changes quick and easy.
Large throat clearance is provided, both vertically and horizontally, for grinding large and odd-shaped workpieces. Adjustment of the tool rest and platen are tool-less to save operator setup time.
Safety measures include an innovative dust port that directs sparks to the rear of the grinder and away from the operator. The 3 in. dust port mounts easily to a metalworking dust collector. Also, the power switch has a safety key to prevent accidental startups. All three belt grinders are CSA/US certified.
The belt grinders are driven by motors ranging from ¾ to 3 HP with constant belt speeds of 5,500 to 8,000, respectively. The 2” x 60” machine is available in single or three-phase models to allow installation in different shop environments.
The JET 1” x 42” three-wheel belt bench grinder (577100), JET 2” x 48” three-wheel belt bench grinder (577125), JET 2” x 60” three-wheel belt bench grinder – 1Ph (577150) and JET 2” x 60” three-wheel belt bench grinder – 3 Ph (577153) are covered by a 2-year warranty, as well as JET’s RED Assurance.
- abrasive
abrasive
- clearance
clearance
- flat ( screw flat)
flat ( screw flat)
- grinding
- metalworking
metalworking
