The industrial automation world is constantly searching for ways to increase installation reliability, speed up the installation process, and reduce downtime. Junction blocks, often referred as terminal blocks and distribution blocks, provide a simple and effective way through consolidating connections from various types of control systems and sensors that have many I/O points.
Mencom Junction Blocks offer a range of circuit configurations in 7/8-16 MINI series, M12 & ½-20 Micro series, M8 Nano series and DeviceNet series. They feature a homerun connector (cable, cable with connector, receptacle or field wireable), which easily routes signals from multiple inputs back to the main control system. This significantly reduces potential errors associated with wiring, rewiring and I/O replacement. Furthermore, both cost and downtime are also minimized.
The port configuration varies by the series with a choice of one or two signal per port.
The 7/8-16 MINI series is available in 4-, 6- and 8-port configurations with an optional stainless steel housing.
The Micro Series and DeviceNet are available in 4 to 12 ports with and without LED indication.
The M8 Nano series is available in 4 to 8 ports with and without LED indication
Mencom Junction Blocks are IP67 rated for a wet environment, and designed to endure high-impact and vibration so that a reliable connection is consistently provided on the harsh manufacturing floor. Mencom also offers custom solutions from small changes to complex terminations to meet the various needs of control systems in the automation industry.
