![Klüberpaste ME 31-52 White/Beige Lubricating Paste Klüberpaste ME 31-52 White/Beige Lubricating Paste](/sites/default/files/styles/product_image/public/product_images/Kl%C3%BCber-Product-Range_1.jpg?itok=SDNILRxI)
Klüber Lubrication has introduced Klüberpaste ME 31-52, a white/beige lubricating paste based on mineral oil, calcium complex soap and inorganic solid lubricants. Besides its application as a universal assembly paste, the paste offers benefits in friction points with small to minimum motion under high static and dynamic loads.
Klüberpaste ME 31-52 can be used for the assembly of frictional connections, e.g. annular springs or split taper sleeves, and positive connections, e.g. bearing seats, profiled guides, etc. The product is for the lubrication of clamping chucks. High precision and constant clamping forces are essential requirements in chucks. Any decrease of the clamping force may cause tools or workpieces to become loose.
Klüberpaste ME 31-52 improves the sliding behavior of moving chuck components, enables a good transmission of clamping forces and can therefore be used in all types of chucks, such as scroll, cam and spiral chucks. Klüberpaste ME 31-52 also prevents stick-slip and protects against tribo- and fretting corrosion in frictional or positive connections.
- chuck
chuck
