Klübersynth FB 4 Series Synthetic Spindle and Hydraulic Oil
Klüber Lubrication offers Klübersynth FB 4 series, an ultrafine filtered synthetic spindle and hydraulic oil that extends component life and reduces operating costs. Oils in the Klübersynth FB 4 series lubricate rolling bearings of high-speed machine tool spindles.
December 20, 2016
Klüber Lubrication offers Klübersynth FB 4 series, an ultrafine filtered synthetic spindle and hydraulic oil that extends component life and reduces operating costs. Oils in the Klübersynth FB 4 series lubricate rolling bearings of high-speed machine tool spindles. They can also be used in hydraulic systems and components, including dirt-sensitive servovalves where cleanliness standards and/or classes are predetermined by the manufacturer.
"The three oils in the Klübersynth FB 4 series, ISO VG grades 32, 46 and 68, help reduce wear caused by fine dirt particles in the lubricant, and can lengthen component life due to a higher purity of the oil," explains Bill Watson, regional director of marketing and engineering for Klüber Lubrication NA LP. "A fully synthetic base oil also helps extend oil change intervals and improve total cost of ownership in a hydraulic system."
Klübersynth FB 4 series are PAO oils of purity class 15/13/10 in accordance with ISO 4406.
