Metabo Corp. offers the KNSE 12-150 Fillet Weld Grinder for finishing various metals including stainless steel. The new extended nose grinder is used for finishing and polishing hard to access fillet welds typically found on handrails or inside welds on enclosed areas.
The KNSE12-150 is a special tool with an extremely flat design that enhances the tool's overall operation and maneuverability. Weighing just 6.6 lbs. and equipped with Metabo's Marathon motor, this new tool is designed with double gear reduction for extreme power delivery.
Standard features include a winding protection grid, auto-stop carbon brushes and thumbwheel for speed preselect. The Vario Tacho Constamatic (VTC) full-wave electronic speed control feature keeps the tool's speed nearly constant under any load.
Safety features of the KNSE12-150 include an electronic soft-start, a toolless adjustment for the grinder's protective cover, overload protection and a power interruption protection. The KNSE12-150 can take a weld from raw to mirror finish using the available accessories.
- fillet
fillet
Rounded corner or arc that blends together two intersecting curves or lines. In three dimensions, a fillet surface is a transition surface that blends together two surfaces.
- flat ( screw flat)
flat ( screw flat)
- polishing
polishing
