Kushion Kut Discs
Kushion Kut Discs
Utilizing a newly engineered flexible backing, highly flexible Kushion Kut quick-change discs from Superior Abrasives are for contour sanding.
July 12, 2012
Utilizing a newly engineered flexible backing, highly flexible Kushion Kut quick-change discs from Superior Abrasives are for contour sanding. Perfect for transition grinding where gouging the work surface is not an option.
Using premium aluminum oxide grain ensures long life and a repeatable finish. Reducing the rpm enables any new operator the finessed control needed.
  • aluminum oxide
