LamCam Universal Cams
DaytonLamina introduces the LamCam line of universal compact cams.
September 1, 2014
DaytonLamina introduces the LamCam line of universal compact cams. With 13 series of Aerial and Die Mount Universal Cams, this comprehensive lineup covers all applications, from low-volume light duty to high-volume heavy duty. Cam widths are available from 50mm to 600mm, each with common footprint to other cam manufacturers.
LamCam Universal Cams are offered with single or double wear plates for ease of maintenance, and either mechanical or nitrogen spring return. A V-guidance system ensures precision guiding. Products are available worldwide, with industry-leading deliveries. Service and support provided through DaytonLamina's extensive technical support network.
LamCam universal compact cams are ideal for piercing, flanging and trimming operations. They are available from 0 to 75 degrees.
