Latest Release of WorkNC CAM/CAM Software
The latest release of Vero Software's WorkNC high-performance CAD/CAM solution for machining complex geometries is said to be the next step on its quality journey. Brand Manager Miguel Johann says the new and enhanced functionality in WorkNC 2018 R2 keeps users at the cutting edge of technology.
May 4, 2018
An important update to the CAD operation is the 2D drawing function in WorkNC Designer. This improves communication with the shop floor by extracting 2D, sections, and detail views from 3D models, while also documenting the part or assembly on a sheet.
The new Wall Machining Strategy is a toolpath for vertical walls in large dies. "It gives a cleaner, safer toolpath, by using the 2D curves at the top and bottom limits of those faces," explains Johann. "The user benefits from a quicker way of calculating and producing the toolpaths."
Pocket Machining with Waveform is a new pattern on the consolidated 2D Pocket Machining, complementing the existing 3D Waveform roughing strategy. It means curves can be selected instead of surfaces, speeding up the calculation time.
An offset can now be defined when selecting an STL model to be cut from stock, which he says leads to safer, more precise stock analysis, as the part might have had thermal treatment, and the size may have changed.
"Without doubt, 2018 R2 is the best version of WorkNC, and the development team have worked solidly over the last three years responding to our users' needs, so the software exceeds our current customers' expectations, and makes it an exciting prospect for new users," he added.
