For use with any Lista universal cabinet, the new leveling base is designed for an easy aftermarket installation that achieves optimal performance and professional ease of use.
Lista industrial cabinets offer the highest density storage combined with an infinite variety of cabinet footprints and drawer heights. Lista cabinets can be customized with everything you need to create the most productive work environment, no matter what your industry or application.
The new bases are available in four heights and 14 footprints.
New Features:
• Ability to adjust at all four corners from inside the cabinet
• One inch (1") vertical adjustment at each corner
• 8,000 lb. capacity
• Two-piece sliding front cover assembly
• Available in plain steel, galvanealled, and galvanealled with stainless steel cover Internal rear support is notched to align with glide adjustment point
