LMT Tools adds WPR-AP indexable insert for finishing
LMT Tools has introduced the WPR-AP indexable insert from its CopyLine range for finishing and semifinishing operations. The LMT Kieninger insert uses a ball-shaped copying edge, LCHK05M cutting material and Nanomold Red³ coating.
LMT Tools positions the insert as an alternative for finishing applications otherwise using solid carbide tools.
The spherical copying cutter is compatible with LMT Kieninger’s existing screw-in, steel and solid carbide holder systems. Users can select the holder for their application while retaining existing systems.
Applications include steel, cast steel, high-temperature-resistant materials and hardened steels up to 60 HRC. Typical uses include die and mold making, mechanical engineering and energy technology. The insert is available in sizes from 10 to 32 mm.
Source: LMT Tools news release. Edited by CTE staff.
