LN4-11 Helical Milling Cutter
Achieve up to three times longer tool life and enhanced productivity with Seco's latest helical milling cutter.
The Seco LN4-11 Helical Milling Cutter sets a new benchmark for efficiency, delivering up to three times longer tool life per edge and reducing the cost per part. Designed for applications requiring diameters between 32 and 63 mm, the cutter achieves high material removal rates, making it a versatile choice for general engineering, automotive, and aerospace sectors.
Engineered with cost-effectiveness and usability in mind, the LN4-11 features inserts that are easy to replace without risk of incorrect placement, reducing waste and downtime. Operators can switch between applications simply by changing inserts, helping shops minimize tooling inventory and associated costs. Each cutter is equipped with a unique Data Matrix code for instant access to cutting data, spare part tracking, and compatible tooling information.
The LN4-11 includes two insert types: front inserts with two cutting edges and helical inserts with four. This design ensures reliable, aggressive material removal while enhancing tool life and overall cost performance. Inserts are available in a variety of grades and geometries to handle a wide range of operations and materials.
By combining robust performance, adaptability, and advanced tracking technology, the LN4-11 provides shops with an efficient solution for increasing productivity and meeting the demands of modern manufacturing.
