Lubricant, Cleaner and Corrosion Protection Products
Many times little and nagging shop problems, such as corrosion, lubrication and contamination of Machinery and parts can cause big headaches. And just like the little white pill, which will take away your pain Oelheld has come up with the cure in a can.
LubTool 2000 lubricates, cleans, protects and removes corrosion, even in extreme low temperatures. LubTool 2000 is NSF H1 approved, so it can be used around food stuff and it is neutral to all common plastic-and elastomeric materials. LubTool 2000 is free of silicon, acids and resins.
LubTool 4000 is a highly effective cleaner. Its combination of active cleaning components removes a wide range of contaminations. LubTool 4000 is especially suited for the removal of resin, oil and grease, most coatings, paints and crayon marks, as well as cleaning of soiled machinery components. LubTool 4000 is also ideally suited for surface prep, prior to bonding and painting. The product is free from hydrocarbons and evaporates residue free.
LubTool 6000 is a modern product which forms a thin, grease-like protective film. It offers reliable corrosion-protection on metal parts for long-term storage indoor and outdoor storage. LubTool 6000 does not form any resins and can be easily removed after long-term storage. As an added benefit treated parts can be EDM wire-cut without removing the coating first. LubTool 6000 is free from FHC, CHC and FCHC.
