M-BRAD Miniature Brushes
PFERD miniature brushes for cleaning and light deburring give users a competitive advantage by providing highly repeatable deburring and surface-conditioning results on a variety of materials, from hard alloys to soft aluminum. The lineup of wheel, cup and end configurations includes stem-mounted miniature brushes that are ideally suited for the precision applications required in many industries, including electronics, medical, aerospace and jewelry.
The brushes are available with a wide selection of filaments, including: carbon steel wire, stainless steel (INOX), brass wire, aluminum oxide abrasive filament and a variety of soft or stiff natural bristles. All the stem-mounted miniature brushes are mounted on 1/8-in. stems, and are recommended for use with variable speed die grinders. Wheel brushes come in diameters up to 1-1/2 in., cup in 9/16 in. diameter and end configuration to 5/16 in. diameter.
The innovative M-BRAD, available as an aluminum oxide filament is a 6.12 nylon microfilament that evenly encapsulates various abrasive grit particles on the surface as well as throughout the nylon filament. The flexibility of strands makes it uniquely effective when deburring complex parts. It yields consistent gradual cutting action, permitting precise control in applications ranging from cosmetic surface preparation on brass or soft aluminum, to edge blending on materials as tough as titanium and carbide. They are also effective on materials such as wood or glass. In addition, M-BRAD brushes yield longer tool life than nonwoven synthetic abrasive products, and are suitable for both wet and dry surface conditioning, although the use of coolant is recommended.
The effective cleaning action of these brushes removes sharp cross-hole burrs, metal sliver residues and sharp corners that result from the drilling of close-tolerance hard metallic and nonmetallic parts.
