![AIR-TIP Trade Focused Vacuum Accessories M12 AIR-TIP Utility Nozzle](/sites/default/files/styles/product_image/public/product_images/0980-20_3.png?itok=YmLjQgbt)
Milwaukee Tool set out to solve user needs with 19 innovative AIR-TIP™ Trade Focused Vacuum Accessories that are fully compatible with other wet/dry vacuum brands. Setting a new standard for products once seen as a commodity, Milwaukee Tool focuses on innovation at the end of the hose. The range of new vacuum accessories includes new to world designs, improvements to dated options, and integration of cordless technology to the vacuum accessory line for maximum efficiency throughout the workday. These improvements will help users clean faster, reach places they have not been able to reach before, and upgrade the overall jobsite cleanup experience.
By incorporating cordless technology, Milwaukee improves the clean-up process with the M12™ AIR-TIP™ Utility Nozzle. Powered by an M12™ REDLITHIUM™ Battery, the power brush roll agitates debris for deep cleaning applications. For increased productivity, the tool allows for more clean-up in one pass compared to a standard floor vacuum attachment. In addition to performance, the universal accessory is built with an LED light for increased visibility in low lit environments.
In addition to the introduction of cordless technology, Milwaukee brings new to world designs to the jobsite cleanup space with innovative AIR-TIP™ solutions. The AIR-TIP™ Magnetic Utility Nozzle features a new-to-world design allowing users to catch metal hardware. The magnetic strip above the nozzle prevents damage to the bags and filters inside the wet/dry vacuums by reducing the amount of hardware that passes through the hose. In addition, the new AIR-TIP™ Long Reach Flexible Micro Hose Set has five interchangeable hose lengths and diameters for greater access in the hard-to-reach spaces on the site. An easy, quarter-turn installation process for each micro hose attachment keeps the professional moving throughout the day.
Comparatively to the new-to-world designs, Milwaukee also innovates dated products with solutions that improve efficiencies to cleanup applications. For instance, the new AIR-TIP™ Cross Brush Tool was designed with cross brush bristles to prevent clogging and provide easier clean-up compared to the traditional round dust brush. The AIR-TIP™ Claw Utility Nozzle w/ Brushes, make handheld clean-up more effective with the ergonomic claw grip design and bristles for more cleaning leverage. Similarly, the AIR-TIP™ Rocking Utility Nozzle w/ Brushes make handheld cleanup easier with bevels on either side of the nozzle and brushes all around the tool to ensure it will not get stuck to surfaces when users are cleaning. As a versatile solution, the AIR-TIP™ accessories are compatible with 1-1/4", 1-7/8", and 2-1/2 Milwaukee Tool hoses and other 1-1/4", 1-7/8", and 2-½ diameter hoses.
With the introduction of these AIR-TIP™ Trade Focused Vacuum Accessories, Milwaukee Tool has taken the cordless, new-to-world designs, improvements to dated accessories, and spanned the innovation across 19 products to change the way users cleanup on the jobsite.
