Milwaukee Tool rounds out its cordless grinding lineup with the addition of new small-angle grinders that generate the power of 13 amp corded. Featuring a full 6” grinding capacity, the M18 FUEL 4-1/2” to 6” Braking Grinders include Rapid Stop to automatically stop all accessories in less than 3 seconds. With the addition of these new tools, Milwaukee offers a full range of cordless grinders that outperform corded on one battery.
The M18 FUEL 4-1/2” - 6” Braking Grinders feature a kickback-reducing clutch and a Rapid Stop brake that stops all accessories in under 3 seconds. This feature ensures that the accessory comes to a quick and complete stop, allowing the user to set down the tool and move on to the next task without having to wait for the wheel to stop. The new grinder will be offered with a no-lock paddle switch configuration and a lock-on slide switch configuration to accommodate user preferences.
Equipped with Milwaukee’s M18 REDLITHIUM HIGH OUTPUT XC6.0 Battery, the tool eliminates the hassle of cords or constant switching-out of multiple battery packs, while exceeding the performance of higher voltage solutions in the industry. In conjunction with REDLINK PLUS Intelligence and the POWERSTATE Brushless Motor, the HIGH OUTPUT Battery allows users to remove more material on a single pass using any 6” accessory.
This is also a 100 percent tool-free product. Whether the user is adjusting the guard or replacing accessories, all changes can easily be made without a wrench, utilizing a FIXTEC nut.
- grinding
