Introducing Walter’s solid carbide universal milling cutters MA230 Advance – a new benchmark in universality and excellence. Suitable for diverse applications and materials, these endmills boast unparalleled performance, thanks to this highly engineered geometry paired with Walter's WJ30EN or WJ30TF high-performance grades.
Program overview
Universally applicable for all common materials and milling strategies.
Walter's MA230 Advance milling cutters adapt to most ISO materials and milling approaches. The extensive range includes options like corner radius, corner chamfers, reduced neck, and unequal helix. The helix pitch is meticulously aligned with the number of teeth, ensuring unmatched running smoothness. Your choice, your precision.
- z3: for grooving, keyway slot milling and profile milling
- z4: for grooving, helical milling, plunging, and ramping
- z5: for roughing and finishing
- z7-9: for dynamic milling and finishing
With Walter’s MA230 Advance you are ideally positioned for the majority of your roughing and finishing applications.
Your Advantages
Universal milling with power – plug & play.
In addition to excelling in nearly all ISO materials, Walter’s MA230 Advance milling cutters impress with their versatile applications, user-friendly handling, and reliable processes. We prioritize delivering these benefits with an exceptional price/performance ratio, ensuring economic efficiency.
Your MA230 Advance advantages summarized:
- Uniquely broad product program – suitable for majority of milling applications
- Flexible usage: one family for all applications and various milling strategies
- Time-saving and easy to handle thanks to plug & play
- High cost-effectiveness thanks to excellent price/performance ratio and extended tool life
- grooving
grooving
- pitch
pitch
