Magnetic Separators
Magnetic Separators
Eriez offers a wide assortment of magnetic separation equipment to effectively and efficiently remove ferrous chips, parts and fine contaminants in metalworking applications.
July 1, 2014
Eriez offers a wide assortment of magnetic separation equipment to effectively and efficiently remove ferrous chips, parts and fine contaminants in metalworking applications. A range of magnetic separator models in various sizes, styles and magnetic strengths are available to provide a solution for practically any requirement.
Magnetic Traps remove ferrous contaminants in liquid lines and capture chips and fines from coolant. They can be easily installed in a machine tool plumbing system to immediately increase purity.
Magnetic Drum Separators utilize the power of Rare Earth magnetic material to expertly separate ferrous parts from abrasive media and other materials. The complete line includes standard models in diameters from 12 to 36 inches (305 to 915mm) and widths from 12 to 60 inches (305 to 1,525mm).
Magnetic Grates, used in coolants, media and sand blasting, extract small and fine ferrous material. These advanced separators come in an array of styles in both ceramic and rare earth designs.
Magnetic Coolant Cleaners, available in four models and multiple widths, provide a powerful solution for removing ferrous contaminants in fluid. These rugged and powerful units can handle up to 600 gallons per minute of water-soluble coolant.
