MaxiMill – 211-DC
June 03, 2024
MaxiMill – 211-DC Optimizes Coolant Supply for Machining Heat-resistant Materials
Developed specifically for heat-resistant materials such as titanium and other super alloys, CERATIZIT has launched their new, additively manufactured MaxiMill – 211-DC indexable insert milling system with advanced coolant supply.
For heat-resistant materials, conventional milling systems are limited and unpredictable. The MaxiMill – 211-DC was created through in-house additive manufacturing with 3D- printed cooling channels. Additive processes allow the patented shoulder mill to funnel the maximum amount of coolant directly on the insert flanks. In turn, it provides process reliability when machining heat-resistant super alloys.
The MaxiMill – 211-DC has 60% longer tool life compared to tools with standard cooling. Further, despite the complexity of the coolant holes inside the tool body, the MaxiMill – 211-DC is compatible with standard adapters with through-coolant supply without requiring any standard coolant on the chip breaker.
“We put additive manufacturing to work for our customers and to achieve results that are only possible when we push boundaries,” says Dan Cope, President of the Americas for CERATIZIT Group. “Titanium and other super alloys are unconventional materials that require unconventional strategies.”
  • alloys
    alloys
  • conventional milling ( up milling)
    Cutter rotation is opposite that of the feed at the point of contact. Chips are cut at minimal thickness at the initial engagement of the cutter’s teeth with the workpiece and increase to a maximum thickness at the end of engagement. See climb milling.
  • coolant
  • gang cutting ( milling)
  • indexable insert
    indexable insert
  • milling
  • milling machine ( mill)
PRODUCTS
06/24/2024
Vargus, a global leader in threading, grooving, and deburring solutions, proudly introduces the FS…
06/12/2024
The 30-tool magazine provides flexibility for milling and drilling applications. The machine…
06/12/2024
ARIA’s Standard Base option is designed for various industry applications where flexibility and…
