MCA II articulated arms
Nikon Metrology recently introduced the MCA II range of articulated arms with a measurement volume between 1.8 meters and 3.6 meters in diameter. Equipped with the brand new ModelMakermmDx, the MCA II is an ultra-modern and accurate handheld scanning combination that is said to handle every inspection task, regardless of specimen size, material and location.
June 1, 2010
Nikon Metrology recently introduced the MCA II range of articulated arms with a measurement volume between 1.8m and 3.6m diameter. Equipped with the brand new ModelMakermmDx, the MCA II is an ultra-modern and accurate handheld scanning combination that is said to handle every inspection task, regardless of specimen size, material and location.
Driven by a growing market demand for faster and more detailed inspection, articulated measuring arms are increasingly equipped with laser scanners to realize a digital inspection process. The concept of digitizing samples up-front and running inspection on the digital copies of the samples offers distinct flexibility and automation benefits. Powerful handheld measuring solutions—combining an MCA II with a digital ModelMaker laser scanner—offer a broader application scope, better ergonomics and unparalleled productivity.
MCA II incorporates premium Heidenhain rotary encoder technology. MCA II 6-axis 1.8m articulated arms realize 16µm in a volumetric length accuracy test, which determines length measurement accuracy of the arm across its entire workspace. Subjected to the same test, Nikon Metrology's MCA II 1.8m 7-axis metrology series achieves 25µm accuracy, ideal to complement the high-precision ModelMakermmDx.
