MEAS High-Efficiency Milling Cutters
The MEAS provides you with a broad range of applications from facing, shouldering, slotting, and profiling to pocketing, ramping and plunging. The sharp insert designs feature Kyocera's proprietary hydrogen-free DLC coated PDL025 grade to maintain excellent wear resistance in aluminum.
Kyocera Precision Tools releases a new milling line for high-speed aluminum applications. The MEAS series is engineered with unique, grooved insert pockets for added stability when machining at high speeds. Utilize simultaneous 3-axis machining with a maximum ramping angle of up to 20 degrees. The MEAS provides you with a broad range of applications from facing, shouldering, slotting, and profiling to pocketing, ramping and plunging. The sharp insert designs feature Kyocera's proprietary hydrogen-free DLC coated PDL025 grade to maintain excellent wear resistance in aluminum.
