Metal Cutting Circular Saw Blades
Engineered with a hand-tensioned, hardened alloy steel body, these new blades deliver the highest quality cuts in the market. The Milwaukee Metal Cutting Circular Saw Blades are equipped with carbide-tipped teeth with alternate top bevel grind to shear through metal, leaving burr-free and cool-to-touch cuts.n
June 10, 2020
Milwaukee Tool continues to enhance their line of unique cutting solutions with the expansion of their Metal Cutting Circular Saw Blade line. Designed specifically to exceed expectations in the most demanding metal cutting applications, these new blades last longer, cut cleaner, and cut faster – without a lubricant.
The new Metal Cutting Circular Saw Blades will be available in sizes ranging from 5-3/8" to 14". These circular saw blades will be available for purchase at select distributors in July 2020.
  • circular saw
    Cutoff machine utilizing a circular blade with serrated teeth. See saw, sawing machine.
