![](/sites/default/files/styles/product_image/public/product_images/BirchwoodMicroLokMZNr1.jpg?itok=8-l_QOoR)
Now it is possible to operate an In-House Zinc Phosphate processing system utilizing almost no rinse water. Using MICROLOK MZN with the Near-Zero Water Recycler and Ion Exchange from Birchwood Technologies, water consumption is reduced by 99 percent. For zinc phosphate users in water-restricted areas, this is a major improvement – it means they can continue critical metal finishing operations while observing tight water guidelines.
The Near-Zero Water Recycling System is useful in areas where restrictions have been imposed due to water shortages, or where normal city water and sewer services are not easily accessed. For example, in rural shops on septic systems, in sewer districts that restrict total water volume, or in plants where the blackening line is located in a warehouse without water/sewer hookups. In all these cases, the Near-Zero Water Recycling System can be installed on a new MICROLOK MZN Zinc Phosphate line, or on an existing line as a retrofit, and can make the difference between successful in-house zinc phosphatizing and no processing at all.
Birchwood Technologies' system utilizes a combination of Ion Exchange and Near-Zero Water Recycler with its proprietary MICROLOK MZN Zinc Phosphate product. The resulting zinc phosphate coating forms a friable, sacrificial surface treatment that improves break-in lubricity of mating/sliding surfaces such as piston/cylinder assemblies, gears, bearings and similar components. In addition, the process is effective for eliminating galling of critical threaded parts that must withstand repeated break-in cycles to function properly in the field.
- galling
galling
Condition whereby excessive friction between high spots results in localized welding with subsequent spalling and further roughening of the rubbing surface(s) of one or both of two mating parts.
- lubricity
lubricity
Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
