Mikron back chamfer milling tool
A milling cutter from Mikron Corp. Monroe is for back chamfer milling of small contours and bores, starting from 0.4mm in diameter. The company recommends conventional milling in two steps to avoid secondary burrs.
A milling cutter from Mikron Corp. Monroe is for back chamfer milling of small contours and bores, starting from 0.4mm in diameter. The company recommends conventional milling in two steps to avoid secondary burrs. Standard sizes are from 0.36mm to 5.7mm for holes up to 5 diameters deep. Specials can be ordered, including ones for simultaneous deburring and chamfering of the front and back side of a workpiece.
