MILLHOG Rolling Motors and Tube Expanders
A full line of pneumatic rolling motors and tube expanders for straight-, flare-, long-reach and beaded rolls that prevent over and under expansion are available for sale or rent from Esco Tool.
May 31, 2016
Esco MILLHOG rolling motors and tube expanders are air-powered and enable users to create a uniform and tight mechanical seal on all types of rolls. Featuring a torque control setting which stalls the tool when it reaches the desired tube expansion, they are supplied as complete kits with a choice of tube expanders for straight-, flare-, long-reach and beaded rolls.
Available with hundreds of tube expander variations for tubes from 3/8" to 4-1/2" OD and tube sheets to 5-3/8", Esco MILLHOG rolling motors and tube expanders are easy to adjust and allow precise torque control from 25 to 325 ft.-lbs. Available with 90-, 190- and 280-rpm motors, these right-angle tools are supplied complete and ready to use with standard shop air.
  • shop air
