An upgraded pipe beveler featuring pneumatic clamping with a new motor and gearing that produces low rpm and high torque to pull a thick chip without cutting fluids has been introduced by Esco Tool.
The MILLHOG Tube Weasel air-clamp beveling tool is a right angle ID clamping tool that fits easily between waterwall boiler tubes to perform precision bevels. Featuring a 1.1-hp motor and robust gearing that runs at 125 rpm with high torque to pull a thick chip without cutting fluids, it has a pneumatic clamp that reduces operator fatigue and speeds throughput.
Capable of improving cycle times by up to 600 percent, the MILLHOG Tube Weasel air-clamp beveling tool has a self-centering draw rod, which rigidly mounts into a tube or pipe ID and retracts from the mandrel automatically after milling to minimize friction. Suitable for 0.75” ID to 3” OD pipes, it can be used in any orientation to perform repetitive welding end preps.
- fatigue
fatigue
- inner diameter ( ID)
- mandrel
mandrel
Workholder for turning that fits inside hollow workpieces. Types available include expanding, pin and threaded.
- outer diameter ( OD)
