Milling Tools With Pressed, Radial ISO Indexable Inserts
MAPAL has introduced a milling program with pressed, radial ISO indexable inserts, thus completing the portfolio of standard milling tools. Up to now, the company has mainly focused on a milling program with ground, tangential ISO indexable inserts. These are used in particular for special applications, very large stock removal, unstable conditions or disc milling cutters.
July 12, 2018
MAPAL has introduced a milling program with pressed, radial, ISO indexable inserts, thus completing the portfolio of standard milling tools. Up to now, the company has mainly focused on a milling program with ground, tangential, ISO indexable inserts. These are used in particular for special applications, very large stock removal, unstable conditions or disc milling cutters.
MAPAL has incorporated the comprehensive know-how gathered in these special applications into the new series of milling cutters with radial ISO indexable inserts. The new face, shoulder, slot and shell end facemilling cutters are designed for roughing and for medium machining of cast iron, steel and stainless steel. They have optimally designed tool bodies with the ideal number of teeth for the respective application. Positive and negative indexable inserts made of four different PVD cutting materials, based on newly developed carbide substrates and coatings, are available for the milling cutters.
Depending on the requirement, the most economical version is used. For example, between eight and 16 cutting edges per radial ISO indexable insert can be selected for facemilling and between two, four and eight cutting edges for shoulder milling.
The new tools are convincing in use due to their smooth running and low noise. In addition, long tool lives are achieved due to the possibilities for exact adjustment to the respective material and the respective application.
  • indexable insert
    Replaceable tool that clamps into a tool body, drill, mill or other cutter body designed to accommodate inserts. Most inserts are made of cemented carbide. Often they are coated wi…
  • facemilling
