MILPRO Process Oils
MILPRO Process Oils
Milacron Holdings Corp. announces that its CIMCOOL brand releases a new series of MILPRO Process oils, formulated for slide-way, hydraulic and gear oil applications.
Bruce Koehler, sr. product manager, CIMCOOL Fluid Technology, states: "Our customers see value in partnering with vendors who can supply both the machining and grinding fluids and the process oils used in the machine tools. Through its CIMCOOL product line, Milacron has this capability and can offer a comprehensive portfolio of premium machining and lubricating fluids. This 'one-stop shop' product offering coincides well with the new simplified product nomenclature adopted for the oils. For example, MILPRO WAY 32 is a slide-way lubricant developed to meet ISO 32 standards."
MILPRO WAY oils: MILPRO WAY 32, MILPRO WAY 68, MILPRO SURE WAY 68, MILPRO WAY 220. MILPRO WAY oils are clear -colored lubricating oils designed to reduce friction and "stick-slip" on machine tool slide-ways. They provide a uniform oil film that insures smooth table motion even after extended shutdowns. MILPRO WAY Lubricants are fortified with extreme pressure and tackiness additives to reduce metal-to-metal wear. These way oils provide trouble-free lubrication on all plain bearing slide-ways regardless of table load or way speed.
MILPRO SURE-WAY 68 has been developed with increased demulsibility characteristics, allowing the way lubricant to separate more efficiently from the metalworking fluid, therefore extending the life of metalworking fluids.
MILPRO HYDRAULIC Oils: MILPRO HY 32, MILPRO HY 46, MILPRO HY 68. These products are premium grade hydraulic oils designed to transmit power, provide lubrication, and protect gear systems. MILPRO hydraulic oils are formulated to pass Milacron specifications and industry guidelines for hydraulic oil applications.
MILPRO GEAR Oils: MILPRO GEAR 150, MILPRO GEAR 220, MILPRO GEAR 320, MILPRO GEAR 460. MILPRO GEAR oils are high-quality oils that provide lubrication, cooling and protect geared systems from oxidation. They are commonly used in differential gears and standard transmission applications in a variety of industrial machinery. MILPRO GEAR oils offer extreme temperature and pressure protection in order to prevent wear, pitting, spalling, scoring, scuffing and other types of damage that result in equipment failure and downtime.
These fluids have been successfully tested for compatibility with metalworking fluids.
