Milwaukee Drill/Driver Kit
The Milwaukee Drill/Driver Kit is changing the way its users work through fastening and drilling up to 35 percent quicker than tools of the same caliber. The powerful, cordless tool boasts 275 lbs of torque. Its durable, lightweight design makes it much more efficient on job sites, increasing productivity and performance.
We are always looking for ways to save time. The Milwaukee Drill/Driver Kit from International Tool is changing the way its users work through fastening and drilling up to 35 percent quicker than tools of the same caliber. The powerful, cordless tool boasts 275 lbs of torque. Its durable, lightweight design makes it much more efficient on job sites, increasing productivity and performance.
The drill's on-board battery fuel gauge allows users to monitor remaining battery life. The tool comes with two batteries, each one lasting 1.5 hours of run time. The kit comes with a rugged plastic case including:
- The Drill
- Two Batteries
- Battery Charger
- Plastic Case
The kit also includes a Bluetooth speaker all for one fantastic deal and can connect to any Bluetooth device while also having an audio input port.
The 12-volt drill weighs 2.7 lbs with bit holder and bit in place making it lightweight and easy to handle. This "quick loc" driver is perfect for ultrafast change outs; its slim design makes it easy to fit in a tool belt. The drill/driver is great for indoor and outdoor projects and is an ideal all in one tool. It is durable, easy to use, and surprisingly powerful for its small frame. Use it for small drilling and driving tasks. The apparatus is useful for normal drilling jobs and gentle enough for setting screws without stripping heads. It also works great when installing wall outlets and switches as well as for drilling holes in floor beams for wiring. If you need something lighter in weight and is small enough to get around small spaces, this kit delivers exactly that.
