Model 496 Split Ring Pliers
A tool that is especially designed to open a split ring and hold it for assembling a wide range of products such as fishing lures, jewelry components, key chains and lanyards has been introduced by Xuron Corp.
The Xuron Model 496 Split Ring Pliers is an ergonomic hand tool designed for the sole purpose of opening a split ring and holding it. Suitable for all size split rings down to #00, this handy pliers eliminates the need for multiple hold and pry tools and the potential for broken fingernails.
Essentially a long-nose pliers with a curved catch tip and a notched tip that team up to grasp and open a split ring, the Xuron Model 496 Split Ring Pliers is made from high-carbon tool steel that is heat treated, covered with nonslip Xuro-Rubber cushioned hand grips and has a return spring.
