Model VR8 Variable-Volume, High-Pressure Coolant System
MP Systems offers a new variable-volume, high-pressure coolant system (HPCS), the Model VR8. The VR8 is part of MP Systems' new Variable Volume VR series. The VR series is engineered to be durable and energy efficient. It also allows users to take full advantage of the flexibility and range of capabilities found in today's sophisticated machine tools.
March 17, 2017
"The VR Series is more efficient, and only uses as much horse power as is required to make set pressure," MP Systems Product Manager Sean Devlin said. "The high pressure system will automatically adjust the gallons-per-minute (GPM) output to maintain the desired set pressure." Pressure can be adjusted from the VR system's primary logic controller (PLC) and controlled by the machine's M codes.
VR series HPCSs have 50- or 70-gallon vertical reservoirs, depending on the model, and can be used with water or oil-based coolants. All come with two quick-change, large-capacity filter bags, a machine installation kit, and a 2-year parts warranty. MP Systems works with end users' machine tool distributors to determine the most suitable coolant systems for each machine and application.
MP Systems Business Development Manager Jill Taylor said the VR8 is priced at $11,995, noting that installation is not included. The price is still about 30 percent less than similar HPCSs on the market, she added.
"We wanted to provide our customers with a smart system that would allow them more range of capability for a great price," Taylor said. "The VR8 will give them a variable volume system, up to eight gallons per minute, along with up to four programmable pressure settings for a wide range of tooling applications."
