Modular spray system
The FlexiSan Modular Spraying System from BETE, a division of Exair, offers a portable spray solution that the company says enables mobility and effective cleaning and sanitization across a wide range of industrial applications.
March 3, 2026
The company says FlexiSan system allows operators to quickly rinse and apply cleaning and sanitizing agents to a variety of equipment, including conveyors, hoppers, bins, and mixers, as well as other critical process areas.
The FlexiSan is designed to handle everything from light washdowns to heavy cleanups of thicker, more stubborn build-ups. The base model offers a mobile cart with a Clean-in-Place spray header that connects directly to a facility’s water line. With two separate blending pumps, the spray system can hold up to two liquids simultaneously, enabling seamless switching between rinsing, cleaning, and sanitizing. For heavier soil levels, BETE also offers a FlexiSan Max Spraying System, providing additional power. Its precision spraying minimizes waste for the chosen liquid and provides a mobile solution for use throughout a plant.
The FlexiSan system is part of BETE’s portfolio of spray technology designed to optimize performance and efficiency. In addition to modular spraying systems, BETE offers fine spray, air atomizing, tank washing, spiral, full and hollow cone, and flat fan nozzles to support virtually any industrial spray application.
Join the MFGAxis discussion
