Moisture Monitor
Moisture Monitor
Eriez introduces the Moisture Monitor.
July 1, 2015
Eriez introduces the Moisture Monitor. This non-contact electronic scanning device, part of the company's new SMART (System Monitoring and Reporting Technology) product line, helps to prevent excessive water content in recycling processes to increase metals recovery and decrease costs.
Eriez' Moisture Monitor measures the water content of material passing through its inspection field. When installed on a conveyor, it reports the moisture content of the material on the belt as a percentage that can be read locally or remotely via the Eriez Metal Loss Monitor (MLM) web portal.
Mike Shattuck, Eriez Market Manager-Metals Recycling, explains, "This capability is particularly beneficial to the recycling industry as it enable users to better optimize the amount of water injected into the mill to prevent fires and control airborne dust generation. The mill operator is able to assure sufficient water injection while preventing excessive water content which would interfere with separation, increase metals losses and increase costs due to the added water weight of reject material sent to the landfill."
The Moisture Monitor is an easy to operate, hands-off gage. Upon installation, simply adjust to zero and put the gage to work. There is no routine maintenance or recalibration. Calibration check standards are available for confirmation of long-term gage stability.
