MS32-6 Multiple-Spindle Automatic Lathe
INDEX has announced the launch of its next generation MS32-6 multiple-spindle automatic lathe. This newest version of the six-spindle machine brings the benefits of multispindle technology to a broader range of applications thanks to a flexible tool slide platform that greatly reduces changeover times.
February 14, 2020
Accommodating up to 32 mm bar stock, the MS32-6 easily handles a wide variety of complex parts, as the machine is equipped with 12 cross slides, with two V-shaped cross slides equipped with X and Z axes located at each spindle position. C and Y axes, together with live tools, can also be implemented to allow for a broad range of machining processes, including off-center drilling, threading, contouring, hobbing and polygonal turning. All of the machines' slides can also be alternatively configured for grooving or drilling.
Each cross slide in the MS32-6 now incorporates INDEX's patented W-serration locating system that provides µm-accurate alignment of the toolholder. Coupled with the company's newly developed quick clamping device, tools can be set up off of the machine and then quickly installed, reducing tool change times by 50%. Additionally, the machine incorporates the same W-serration system on its live units for drilling, milling and polygonal turning. By presetting tooling for these operations off of the machine, setup times can be reduced by up to 92%.
With the updated MS32-6, users can also now apply twin turrets with rigid tools in up to five spindle positions. These hydraulically controlled units can alternate between tools in less than half a second. This enables the efficient use of separate tools for roughing and finishing in the same position. The twin turrets can also be used to reduce tool changes by incorporating duplicate tools, an option that is especially attractive when working with difficult-to-machine materials.
The machine's fluid-cooled spindle drum features six spindles with speeds that are independently controlled to a maximum of 8,000 rpm. This allows optimal cutting data to be applied to each individual cutting process, resulting in superior metal-removal rates, surface quality and tool life. Additionally, the machine can be equipped with one or two synchronous spindles, each of which can apply up to six tools for machining the rear end of parts.
  • center drilling
    Drilling tapered holes for mounting workpiece between centers. Center-drilled holes also serve as starter holes for drilling larger holes in the same location. See centers; drillin…
  • toolholder
