Multi-V
October 01, 2011
If you have a complex part with multiple operations and limited tool holders, The Magafor MULTI-V from Hassay Savage Co. may just be your answer. Made from K-15 Micro Grain Carbide, these tools can center-spot, drill, chamfer, direct chamfer, v-groove, interpolation mill, contour side mill, longitudinal chamfer side and edge and engrave all in one tool. The MULTI-V provides reduction in set up time with outstanding surface finishes.
The 30 degree spiral flutes provide improved chip removal and the micro grain carbide provides wear resistance and rigidity. Sizes range from .020" to .787" and are all individually packaged in stock ready to ship.
  • flutes
    flutes
  • interpolation
    interpolation
  • milling machine ( mill)
  • wear resistance
    wear resistance
Sponsored Content
