NITEGLOW Two-Stage Safety Nosing
Wooster Products' new NITEGLOW treads with high-quality photoluminescent are ideal for exit path markings, steps and leading edge of landings when finding pathways in the dark is a necessity. This two-stage anti-slip stair nosing meets NYC Local Law 26, 2015 IBC, and 2015 IFC code compliance and is well suited for either new construction or retrofit interior stair applications.
Heat-treated corrosion resistant aluminum substrate and a nearly diamond-hard aluminum oxide filler assures long tread life under heavy pedestrian traffic. Bright, long lasting photoluminescent epoxy filler is free of hazardous and radioactive substances, extends uniformly throughout the filler. A high content of aluminum oxide abrasive provides traction and long service life, and is replaceable. Available in lengths to order, to a maximum of 8'0". Clean architectural lines ensure aesthetic appeal.
NITEGLOW® two-stage safety nosing includes a replaceable anti-slip abrasive-filled top insert, and a mill finish extruded aluminum base, with sure-hold anchor. Optional wood insert keeps aluminum base clean during initial construction. Protective tape also available.
Anti-slip filler includes approximately 60% virgin grain aluminum oxide abrasive which is available in contrasting colors. Photoluminescent epoxy binder is a fully cured resilient epoxy with a filler ratio of 16% minimum for enhanced cleanability.
