Online Gearbox Identification Service
The link between the physical gearbox and the digital world is established via a data matrix code (DMC), a 2D code on the gearbox nameplate. This can be scanned via smartphone or tablet, for example. Alternatively, access is possible via a web portal on the Neugart homepage (www.neugart.com).
Anyone who uses planetary gearboxes from Neugart can now access relevant digital product information even more easily: A new online service links the physical product directly to the documents and digital functions available for it.
This identification, which is as smart as it is reliable, leads immediately and around the clock to the relevant product information and other functions. The user then receives, for example, a clear list of all the versions of the gearbox in question or can download the appropriate operating and mounting instructions.
If customers require a technical adjustment or wish to submit a complaint, they can contact Neugart customer service directly via the connected service request. Furthermore, if a Neugart gearbox shows signs of wear after years of use, an identical replacement gearbox (including express delivery) can be requested conveniently and with just a few clicks via the online service.
Currently, Neugart is converting the newly produced gearboxes to a new nameplate layout with integrated DMC. The online service is starting with the essential functions in the after-sales area and will be successively expanded. For instance, in addition to further product-specific information and documents, new functions are also planned.
