OPTIMAX 365 UV-A LED Flashlight
The Spectroline OPTIMAX 365 from Spectronics is a cordless, rechargeable UV-A (365 nm) LED flashlight that is for nondestructive testing applications such as MPI, FPI and general fluorescent examination.
The OPTIMAX 365 utilizes ultra-hi-flux LED technology to produce a nominal steady-state UV-A intensity of 18,000 µW/cm² at a distance of 15" (38 cm). Its Electronic Intensity Stabilizer assures consistent performance; the beam strength will not weaken between charges. Powered by a rechargeable NiMH battery, the flashlight provides 90 minutes of continuous use between charges. The LED lifetime is 100,000 hours.
The OPTIMAX 365 is extremely lightweight and compact, weighing just 11.8 ounces (335 g). It's ergonomically designed to provide ultimate comfort and freedom of movement during inspections. The flashlight has a corrosion-resistant anodized lamp body, which makes it perfect for use in the field. Just the push of a button turns the lamp on instantly at full power.
The flashlight comes with UV-absorbing spectacles, a rubber lamp protector, a belt holster and smart AC and DC battery chargers, all conveniently packed in a padded carrying case. The AC charger is available in 120V, 230V, 240V or 100V versions.
  • nondestructive testing ( NDT)
    Same as nondestructive inspection but implying use of a method in which the part is stimulated and its response measured quantitatively or semiquantitatively.
