P3 Collet
P3 Collet
The anti-friction coating reduces radial distortion helping improve run-out. Parlec P3 ER collets have a repeatably accuracy of 0.0001" and are sealed for coolant pressures up to 2,000 PSI due to a special slotting design. Parlec P3 ER collets are available in ER11, 16, 20, 25, 32 and 40 in inch and metric sizes and are meant to be used with on-size tooling.
January 26, 2022
Parlec has released the new P3 ER collet system, the first coated ER collet system according to the company. Parlec P3 ER collets feature a special anti-friction coating on the 30° face of the collet that interfaces with the collet nut when tightening during tool setup. According to Parlec, the anti-friction coating reduces radial distortion helping improve run-out. Parlec P3 ER collets have a repeatably accuracy of 0.0001" and are sealed for coolant pressures up to 2,000 PSI due to a special slotting design. Parlec P3 ER collets are available in ER11, 16, 20, 25, 32 and 40 in inch and metric sizes and are meant to be used with on-size tooling. P3 ER collets may be used in any ER collet chuck to improve accuracy and cutting performance.
