Parallel Arm Tapping Tools
Palmgren's Parallel Arm Tapping tools make tapping fast and easy.
August 1, 2015
Palmgren's Parallel Arm Tapping tools make tapping fast and easy. The use of a parallel arm tapping machine will generate savings through improved operator utilization, reduced set-up times, reduced material handling and improved material flow. Customers can select the pneumatic tapping arm system, motor and tap holder that best meets their needs.
The Quick-Tap system features a working area reach of 37 inches and is best suited for small and medium size taps. The Shop-Tap is the choice for general-purpose tapping and has a working area reach of 62 inches. With a working area reach of 55 inches, the Production–Tap can be used for a wide range of general purpose to heavy duty tapping. All three have variable mounting capabilities.
  • tapping machine
    Production machine used for high-volume tapping. Offers repeatability, high production rates and reduced tap breakage. Comes in a variety of configurations, including indexing unit…
