![PCD Fine-Pitch-Tooth Facemill is Resharpenable PCD Fine-Pitch-Tooth Facemill](/sites/default/files/styles/product_image/public/product_images/facemill%20tool%20shank-thumb-280xauto-1004.jpg?itok=Be22porP)
Kanefusa USA Inc. says its fine-pitch-tooth PCD facemill realizes high-speed feeding and high productivity when milling aluminum surfaces. The tool provides high-quality cutting with its precision sharpened edges.
The innovative clamping bolt structure enables lubrication of the cutting edge via a center-hole coolant supply. The brazed edge is resharpenable without runout adjustment. A resharpening service is available upon request.
Specials can be ordered to impart finer surface finishes and prevent burrs.
Click here for more information.
- coolant
- facemill
facemill
Milling cutter for cutting flat surfaces.
- polycrystalline diamond ( PCD)
