![PF Chipbreaker for Microboring PF Chipbreaker](/sites/default/files/styles/product_image/public/product_images/PF_Chipbreaker_Action1.jpg?itok=oyNoe1TC)
Kyocera Precision Tool Inc. offers the new PF chipbreaker for microboring applications. The PF chipbreaker’s low cutting force design and anti-welding properties provide excellent chip control and surface finish in a variety of applications.
With a minimum cutting diameter of 5 mm, the PF chipbreaker works great when paired with Kyocera’s EZ Bar PLUS boring bars.
- boring
boring
- chipbreaker
chipbreaker
Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
- cutting force
cutting force
