PFX Cobalt HSS Drills
Dormer PFX premium cobalt HSS drills are available in screw machine, jobber, taper and extra-length designs. Providing options for drilling applications, the PFX is ideal for most engineering materials drilling 3 diameters deep (A920, A921), 6 diameters deep (A900, A901), 10 diameters deep (A940, A941) and 15 diameters deep (A976, A977, A978).
All drills feature a parabolic flute design for increased chip space and improved chip evacuation capabilities. This design allows greater hole depths to be achieved, in some cases without the need for pecking. A thick web increases the structural strength of the drill for enhanced rigidity and minimizes the risk of drill breakage. In addition, the special point geometry promotes excellent centering, eliminating the requirement for a pilot hole, and reduces thrust force and power requirements.
Available in bright finish across the full range, a Smooth-Flow coating option is available on screw machine, jobber and taper lengths. This AlCrN top coating reduces the coefficient of friction, increases wear resistance and, in combination with the parabolic flute, eliminates chip packing at greater depths.
  • centering
    centering
    1. Process of locating the center of a workpiece to be mounted on centers. 2. Process of mounting the workpiece concentric to the machine spindle. See centers.
  • high-speed steels ( HSS)
  • wear resistance
    wear resistance
  • web
    web
