PHOENIX PFDC indexable facemill cutter and inserts
OSG USA Inc., St. Charles, Illinois, releases the PHOENIX PFDC indexable facemill cutter and inserts, designed for non-ferrous materials. This exchangeable facemill cutter is perfect for small machining centers.
The cutter series, which includes PFDC 52902, 78351 and 78PSF, features:
  • a thin steel body that is lightweight while maintaining high tool rigidity,
  • internal coolant channels to improve chip evacuation,
  • a breaker shape with a sharp cutting edge ideal for machining non-ferrous materials,
  • and compatibility with BT30, ensuring total weight under 3 kg for easy tool management.
View the OSG PHOENIX PFDC product flyer for more information.
  • centers
    centers
  • coolant
  • facemill
    facemill
    Milling cutter for cutting flat surfaces.
