PL36-FB (Freeboard)
PL36-FB (Freeboard)
The Graymills model PL36-FB (freeboard) is the newest member of the durable, long established Handikleen line.
The Graymills model PL36-FB (freeboard) is the newest member of the durable, long established Handikleen line. This model complies with the most common freeboard ratio/rule of .75 for those areas that need freeboard compliant parts washers.
Heavy gauge metal construction, with a durable powder coated exterior, ensures long life. A removable work shelf puts parts at a convenient height. Simply remove the shelf and you have a soak tank. Built-in filtration and a high flow pump deliver effective cleaning and rinsing action through the flexible metal flush hose. These are just some of the features our customers have come to appreciate and expect from Graymills.
